Linux fails to boot on DE10-Nano board
Hi YasuoF,
Can share the full boot up logs error for linux?
Would like to see if any particular failure indication from there.
Terasic DE10 is using Cylone V architecture, can check if there is any difference on the device tree configuration used by Cyclone V:
Aik Eu
- YasuoF2 years ago
Hi, @aikeu
The reason it stopped at that line was due to a bad terminal setting, and the scrolling just stopped in the middle of the line.
I apologize for the inconvenience.However, Linux still does not boot.
It appears that mmcblk0p2 cannot be opened. How can I resolve this issue?
I'll upload the correct log as bootup-log.txt.
Also, I have compared the dts uploaded to Github with the dts created by the above procedure, but there are too many differences to discern what is causing the problem.
