17 years agoLED/Debouncing problems
Hello All, I am trying to test LED/debouncing logic for basic gates. Following is my code module ledtesting ( input clock, input A, input B, output C, output D, output E, out...
17 years agoOK understood now. you mean:
any one button pressed => AND/OR/NAND/NOR work opposite two buttons pressed => all work Sounds difficult now, is your timing ok. I know it is slow clk but you shouldn't ave timing problems. Is your slow clk made global. I suggest you make cnt(24) enable, thus use fast clk on the process but add: if cnt(24) = '1' then.... instead of using cnt(24) as clk. edit: you need to make cnt(24) as one clk pulse
