17 years agoLCD pinnout for Cyclone III dsp kit is wrong
the chip select (enable) pin is marked as AB24 in the refference manual it is actually AC24. just fyi if you are trying to design an LCD driver.
1 Reply
If you plan to use the SRAM too, some signals are not assigned to the correct pins in some design examples... I've put the list in this thread (http://www.alteraforum.com/forum/showthread.php?t=2609).
