Kernel boot hang and reboot issue on Agilex in the U-Boot stage
Hi Jayasurya
Which version of u boot you are using at the moment?
Could you try out printing the env variable in the uboot and share it with us?
After printing the env variable take a look at the boot command, is it using bootm or booti.
If you are using a more recent version (using bootm) could you try loading the .itb format instead of a separate package.
The commands are as follows:
tftp ${loadaddr} <path to itb file>
bootm ${loadaddr} #board-${board_id}
The .itb files is created in the uboot build process.
Jingyang, Teh
Hi JingyangTeh,
Thanks for the reply,
I have followed the below path for generate the U-boot files.
Building Bootloader for Agilex 7 | Documentation | RocketBoards.org
U-Boot Version : "ver=U-Boot 2022.10-24691-gb1598f9fda-dirty (Aug 09 2023 - 10:17:35 +0530)socfpga_agilex"
In the default mmcboot, they have used the booti command for loading the kernel. Thats why I have used the same. Currently after the compilation of the uboot sources, I am executing this command (ln -s u-boot.itb u-boot.bin) to change the file type for loading QSPI flash.
Kindly do the needful for this issue. Thanks in advance.
Jayasurya R.
