dkaws
6 years agojtagconfig not working properly.
I'm using quartus 13.1 installed on ubuntu 12.04 (32-bit) in a Oracle VM. When I tried to connect my cyloneV SoC development kit some times it works but most of the time it's not working.it's very ra...
JohnT_Altera
6 years agoHi,
May I know if the issue is happening if you are not running VM?
- dkaws6 years ago
I didn't check it on similar environment as in VM.
But I hv checked it on
1.windows 10 quartus 17.1 (64 bit)
2.ubuntu 14.04 quartus 15.1 (64 bit) in VM
In above environments it worked fine. (EVEN THOUGH I HAVE TO CHANGE THE JTAG CLOCK SETTINGS (AS YOU MENTIONED) ON 2ND ENVIRONMENT.)
