dkaws
6 years agojtagconfig not working properly.
I'm using quartus 13.1 installed on ubuntu 12.04 (32-bit) in a Oracle VM. When I tried to connect my cyloneV SoC development kit some times it works but most of the time it's not working.it's very ra...
JohnT_Altera
6 years agoHi,
It looks like the issue is happening if you accidentally terminate or exiting the jtagconfig. Could you confirm if you run it normally without terminating it, are you still observing the issue? When you are not able to detect the device, are you seeing the led light?
- dkaws6 years ago
No I don't see and red light. My task is to generate Nios II processor system and upload c program to processor and run it. Even if I successfully upload the system into FPGA I cannot upload my c code most of the time.
