MartinMaa
2 years agoJTAG PULL UP/DOWN RESISITER
Hi, I am writing to ask a question about the pull-up and pull-down resistors used in JTAG signals. If an FPGA has internal pull-up resistors, do I need to add these resistors? If I do need to add th...
- 2 years ago
Yes, FvM is correct. Diodes and capacitor are more critical. The position of the resistor in your design should be fine.
Aiman
MartinMaa
2 years agoThank you for your reply.
Since my PCB is very small, only 36mmX36mm, there are some difficulties in placing the components.
If the distance is as shown in the figure, will there be a problem? Or is there a maximum allowable length?
482mil (12mm)
- FvM2 years ago
Regarding resistors, I doubt there's a strict close to FPGA requirement because resistance is large multiple of trace impedance. Position of capacitors is more critical, a few centimeters don't matter though.
