MartinMaa
2 years agoJTAG PULL UP/DOWN RESISITER
Hi, I am writing to ask a question about the pull-up and pull-down resistors used in JTAG signals. If an FPGA has internal pull-up resistors, do I need to add these resistors? If I do need to add th...
- 2 years ago
Yes, FvM is correct. Diodes and capacitor are more critical. The position of the resistor in your design should be fine.
Aiman
NurAiman_M_Intel
2 years agoHi,
It is recommended to follow the setup in the userguide. For the resistor, it should be put close to FPGA.
Aiman
