16 years agoJTAG ID error
Hi, there I tried to implement Video-over-IP reference design on the Cyclone II dev kit. The Altera website said this reference design support Cyclone II series dev kit, and my one is EP2C35. B...
16 years agoI recompiled it. Yes, it should be a different .sof file. Now the hardware image works. However, when I download the software image .elf file on the board. It shows the following error:
There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. And when I tried to follow the steps on the Nios II Development Kit Getting Started User Guide, the same problem occurs when I Downloading and run the Executable Code to the Nios Development Board. Could anyone give me a hint how to solve it? Since the downloading for the hardware image is ok, I assume the JTAG cable should be fine. Am I right?
