--- Quote Start ---
Now I'm wondering about the MAX II Byte Blaster II. The LED that is stuck on is driven by the MAX II .. does it have internal FLASH ?
--- Quote End ---
Wrong terminology; the circuit you provided an image of is a "USB-Blaster II".
The Cypress FX2 has internal memory and the MAX II has internal memory. Both of these devices need to be correctly programmed with USB-Blaster II firmware (which is proprietary to Altera).
--- Quote Start ---
The attached section of the schematic indicates SCTX is the signal stuck on. ( yellow highlight ). There is a mismatch in the schematic
since the schematic says the associated LED is D9 but the silkscreen on my board says LED D8.
I may have to bring up the .brd file to determine which signal / LED is the actual one stuck on.
--- Quote End ---
SC = SystemConsole, so my guess is that this is the SystemConsole communications interface transmitter LED.
--- Quote Start ---
Anyone have any experience with the MAXII Byte Blaster ... is the RTL design available for me to determine why that LED would be stuck
on when I try JTAG operations and the SW4.3 , "factory_load" is not set on ie user mode ? ... does that mean I have some code in
the FLASH for the FPGA + NIOS that is loading on power up and shutting down the opening the JTAG loop or somehow shutting down JTAG
even when I only have the FPGA in the JTAG path . ie all other JTAG devices bypassed ? That us what the factory inferred .
Also , any hints on getting the BTS to work ... ? I thought I could do a visual check on the FLASH contents on the card that is acting up
vs the good Arria V starter kit card.
--- Quote End ---
I'd recommend filing a Service Request and talking with someone at Altera directly.
If you're seeing differences between two Arria V starter kits, then its possible you have damaged one :(
Cheers,
Dave
