11 years ago --- Quote Start --- Now I'm wondering about the MAX II Byte Blaster II. The LED that is stuck on is driven by the MAX II .. does it have internal FLASH ? --- Quote End --- Wrong terminology; the circuit you provided an image of is a "USB-Blaster II". The Cypress FX2 has internal memory and the MAX II has internal memory. Both of these devices need to be correctly programmed with USB-Blaster II firmware (which is proprietary to Altera). --- Quote Start --- The attached section of the schematic indicates SCTX is the signal stuck on. ( yellow highlight ). There is a mismatch in the schematic since the schematic says the associated LED is D9 but the silkscreen on my board says LED D8. I may have to bring up the .brd file to determine which signal / LED is the actual one stuck on. --- Quote End --- SC = SystemConsole, so my guess is that this is the SystemConsole communications interface transmitter LED. --- Quote Start --- Anyone have any experience with the MAXII Byte Blaster ... is the RTL design available for me to determine why that LED would be stuck on when I try JTAG operations and the SW4.3 , "factory_load" is not set on ie user mode ? ... does that mean I have some code in the FLASH for the FPGA + NIOS that is loading on power up and shutting down the opening the JTAG loop or somehow shutting down JTAG even when I only have the FPGA in the JTAG path . ie all other JTAG devices bypassed ? That us what the factory inferred . Also , any hints on getting the BTS to work ... ? I thought I could do a visual check on the FLASH contents on the card that is acting up vs the good Arria V starter kit card. --- Quote End --- I'd recommend filing a Service Request and talking with someone at Altera directly. If you're seeing differences between two Arria V starter kits, then its possible you have damaged one :( Cheers, Dave
