11 years agoOk ... yes it is a USB-Blaster II ... I'm thinking about the factory comment ... that the application I programmed the FLASH with may be causing trouble.
That is a convoluted case of FLASH corruption ... so I will try to write the FLASH using the update portal with a minimum FPGA code to flash a LED and no NIOS II core. I will try that and see if it helps.
