15 years agoJTAG cable naming error (Terasic blaster)
Hi all, I am having a few issues with when I have multiple Terasic Blasters connected to a single PC. I am scripting a download in order to automate it but have several devices connected, each is ...
15 years agoThe cause for the numbering convention is the same as for FTDI USB COM ports. Perhaps a 'solution' to this issue can be found in FTDI app notes.
http://www.ftdichip.com/support/documents/appnotes.htm For example http://www.ftdichip.com/support/documents/appnotes/an_123_how%20com%20ports_are%20allocated%20on%20driver_installation.pdf http://www.ftdichip.com/support/documents/appnotes/an_132_re-assigning_com_port_numbers_using_registry.pdf Cheers, Dave
