mwac__
2 years agoIssue regarding reading the Analog value from ADC
Hi. I'm working on Altera Cyclone V,SOC DE1 (rev F) board. I need to access the on board available ADC (LTC 2308). The software version I'm using is Quartus ii(13.0,64 bit). The simulation waveform...
KianHinT_altera
2 years agoHi,
Thanks for reaching out to us. I'm Kian and will be looking into your case.
Just some basic question first for debugging:
1. Could you confirm that does the 12bit data output from ADC changes according to the voltage/signal input to the ADC ? Just to check whether the ADC is giving values out or doesn't change at all.
2. If modify your program instead of relying on the 12bit ADC data to a simple counter to change the LEDs, does the LEDs change? This is just to confirm the LEDs are configured correctly and can be controlled in your program.
Meanwhile I will check whether we have some examples or documents that could help in this case.
Kian
