jjang's avatar
jjang
6 years ago
Is There Any Avalon-MM Pipeline slave I/F Example Logic?
i wanna Communicate Logic <-> Nios using Avalon MM Pipeline slave..
is there any Examples?
Nios(Qsys, Avalon MM Pipeline Slave) <-> Logic
  • Eliath_G_Intel's avatar
    Eliath_G_Intel
    Hi Jongyun ,
    I'm Eliath and I'll help you with this, I just have a few questions:
    does your design have a component on Qsys? or it is only code?
    Is VHDL or Verilog the language you are using for the logic?
    Which Quartus version are you using?
    -Eliath
    • jjang's avatar
      jjang
      In my design, NIOS is my master.
      Quartus 17.1 // Qsys(Platform Designer)
      1. Nios
      1.1 Onchip-memory
      1.2 jtag
      1.3 Avalon -MM-Pipelined-Slave (conduit to Logic)
      * Address, Wr_n/Rd_n / ReadData / WriteData / WaitReq / ReadVaild
      i wanna communicate with Vhdl/Verilog Logic .
      Nios <-> Logic
      Main Clock : 50Mhz (Logic, Nios)
      Befored i using without pipelined Options (* ReadVaild, WaitReq)​
      ​--- Without Using (* ReadVaild, WaitReq)​
      proess(RD_n, Address)
      begin
      if RD_n = '0' -- Nios wanna Read Data
      case Address(15 downto 0) is
      when x"0000" => ReadData <= x"00000000";
      when others => ReadData <= x"ffffffff";
      end case
      else
      ReadData <= (others => 'z');
      end if;
      end process;
      i'm not sure what is mean "Maximum pending read Transactions"
      * IF i Set Maximum Pending Read Transactions = 2 then,
      * 1.1 At Slave sides, Read 2 Addr1, Addr2 (When Rising Clock) (Refer Below Timing Diagram)
      * 1.2 After Read 2 Times Slave Asset WaitReq to High
      * 1.3 Wait a Clock Delay (Sync to Where? need to make Another Clock?)
      * IF i Set Maximum Pending Read Transactions = 4 then,
      * 2.1 At Slave sides, Read 4 [Addr1, Addr2, Addr3 ,Addr4] When Rising Clock
      * 2.2 After Read 4 Times Slave Asset WaitReq to High
      * 2.3 Wait a Clock Delay (Sync to Where? need to make Another Clock?)
      refer : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
      Page #. 29
    Eliath_G_Intel
    Hi Jongyun,
    it is not needed to implement one more clock due to the following:
    • New .qsys files include Clock Source component ( clock aggregator)
    • When connecting two interfaces:
      • Clock input interface fed from the outside system (is exported out of the system, by default)
      • Clock Output interface connects to Clock Input Interfaces of other system components.
    • Clock column will help to have a quick clock signal connection.
    I'd like to share an example design for Avalon Memory-Mapped Slave
    in the link, after table one you will find two useful links.
    Please let me know how useful the information was to solve the issue.
    Eliath_G_Intel
    Hi Jongyun,
    Hoping you're well I was wondering if the information I shared with you was helpful and if there's something more I could help you with.
    -Eliath
