Is it possible to run NIOSV through SDRAM ?
Is this the same issue as the one with your 16-bit data bus to your Nios V?
Yes, it is the same issue as of the 16-bit data bus to the NIOSV. If we keep aside the SDRAM, and try to use On-Chip-Ram as program memory, where the data width of On-Chip-Ram IP is set to 16 bits, then same issue arises when running the ELF. The ELF gets downloaded successfully but the Debugger Console shows warning : "Cannot access memory at address 0x29c". When the data width of On-Chip-Ram IP is set to 32 bits everything works fine as expected.
With NIOS II, we were capable to configure the device with 16-bits On-Chip-Ram, but NIOSV does not seems to work like that. So I think due the data width of SDRAM being 16-Bits set in the QSYS system, similar issues are occuring in that cases. Any help regarding to solve this would be appreciated.
Thanks !!!!
Himanshu
- himanshuvaria3 years ago
Any update on the regarding the issue ? Please share your response !!
