17 years agoIP packet rate using DE2 and Nios2
Hello, My goal is to send video over IP using the DE2 kit with nios-2/f. I tried to use Altera's CD demonstration called DE2_NET. I managed to send packets to a directly connected PC using the...
17 years ago@suitcase
Yes, I´ve modified the DM9000.C and more, I´ve reduce the delays times, testing them carrefully. I´ve also add a UDP header, and checking it with the wireshark software. Just only try it, and let me know if you´ve got some improvements. Ideas, etc. Maybe between us we could get a better aproximation of the target. @Frank. Thanks so much for the application note data, sounds interesting.
