15 years agoIP for CAN
Has anybody advice for that?
15 years ago --- Quote Start --- tri states are only available for outside connectivity not inside the fpga between modules. a tristate is done by using an output buffer and controlling its output enable input. --- Quote End --- I don't know how Quartus actually synthesizes the sopc tristate bus. I believe this is not a true tristate. If I connect it to another inside-fpga module it works perfectly. I've already done it successfully both with OpenCore CAN module and with other IP cores exposing an AMI. Cris
