17 years agoInterrupts and RTOS on NiosII
Hi, I'm using the Cyclone III NiosII Embedded Evaulation Kit (NEEK) as a basis for a custom embedded processor design. When using the uC RTOS (necessary for use with the Altera Triple speed Ethern...
17 years ago --- Quote Start --- Hi, I'm using the Cyclone III NiosII Embedded Evaulation Kit (NEEK) as a basis for a custom embedded processor design. When using the uC RTOS (necessary for use with the Altera Triple speed Ethernet soft MAC core), is it still possible to service an external interrupt (generated on a regular basic - say every 250usec) with minimal latency? Tim --- Quote End --- Yes it is possible to service an external interrupt. I have used alt_irq_register () call to register external interrupts (please note that you must experiment with the interrupt width to arrive at an appropriate width to register the irq). The control is then transferred to the ISR.
