Internal Error when attempting to program Agilex 7 on Intel Development Kit
- 2 years ago
Hi Jingyang,
Thank you very much for your help with this. The data points you have provided have helped greatly in debugging and verification of programming procedure.
This case has transitioned over to IPS support. I/We can close this ticket and accept solution.
Brandon
Hi
I just tried out the design that you created.
There is a sof file "pcie_test_hps_auto.sof", I assume it is the final sof that you created with the bootloader combined.
Tried it out on the devkit on my end and the flashing completed successfully.
There are logs from the devkit too, however there are some problem with the ddr calibration. Refer below:
Before we deep dive into your design, lets confirm that the board you are having is working properly.
Have you tried successfully booting the board you have?
If not there are steps on running our GSRD first. Do take note to follow the steps for the DK-SI-AGF014EA.
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD
Jingyang, Teh
