Intel MAX 10 FPGA short issue
Hi ,
To understand more about the issue, can you please share with me some information?
1. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did they violate solder re-flow temperature profiles, moisture sensitivity? Please provide the re-flow temperature profiles.
6. Did you swap the failure device to a known good board? Is the failure following the device or board?
7. Is this a prototype build or volume/mass production?
Thanks!
Please consider of confidential information you might share. If you need to private message, please do let me know.
- SLeon245 years ago
Please refer below for the information requested.
13 out of 1000+
All are line rejects on board level.
- Measure impedance on board and found short from 3.3V to DCOM.
- Remove component on the trace from 3.3V to DCOM one by one to narrow down the issue.
- After removed inductor FL19, no short from 3.3V to FL19. (FL19 is connected to 3.3V and FPGA C7, D7, D8, E8),
- Then, both 5DX and 2DX performed on FPGA and no visible short found.
- Measure impedance from C7, D7, D8, E8 to C8 and D6. (FPGA C8 and D6 are connected to DCOM)
- Remove FPGA from board and measure impedance on board and FPGA, no short was found on board. Short was happened on FPGA.
We did not perform screening for raw FPGA
TBA
Swapping performed on 2 boards, both are working after swap with good FPGA. The failure follows the device.
Mass production
I will upload the re-flow temperature profiles and board schematic once I have it.
I attach schematic of FPGA (U6) for your reference. I do not manage to get the re-flow temperature profiles at this moment.
Please advise can we proceed for FA? If yes, may I have the shipping address?
Shwu Ching
- Zawani_M_Intel5 years ago
Thank you Shwu Ching for all the details provided.
From the statement given, I can get some picture of the issue.
I can see it might be because of electrical overstress (EOS) issue. Power pins short to ground is one of the symptoms of EOS.
In order to avoid electrical damage, the device should always be handled in a static-free environment and all the input signals should remain within specified limits, as recommended in the PSG Data Book and associated application notes, at all times.
For your information, EOS is fall under mishandling issue.
Wani- SLeon245 years ago
We are handling products in ESD safe environment and all this failure are fail at incoming board pretest failure. We have been tested and shipped around more than 1k boards and do not have issues and only seeing this batch failures recently.
Shwu Ching
