Inquiry Regarding MAX 10 FPGA Power Management
- 2 years ago
Based on this Knowledge Article Is it necessary to power all the VCCIO IO Banks on a MAX 10 device... (intel.com), it is recommended to power-up all the VCCIO rails even when not used.
However, you may choose to connect to the power rails to minimum required power mentioned in the datasheet, like 1.0V. Single Supply Devices Power Supplies Recommended Operating Conditions (intel.com)
