MartinMaa
2 years agoInquiry Regarding MAX 10 FPGA Power Management
Dear Intel Technical Support Team, I am currently working with the MAX 10 FPGA and have a question related to power management. Specifically, I would like to understand the power requirements for u...
- 2 years ago
Based on this Knowledge Article Is it necessary to power all the VCCIO IO Banks on a MAX 10 device... (intel.com), it is recommended to power-up all the VCCIO rails even when not used.
However, you may choose to connect to the power rails to minimum required power mentioned in the datasheet, like 1.0V. Single Supply Devices Power Supplies Recommended Operating Conditions (intel.com)
MartinMaa
2 years agoI am not using these I/O pins. Can I remove these resistors and capacitors to make VCCIO non-connected.
