16 years agoInitialising SRAM
Hi, is there a way to initialise SRAM chip at programming time ? Just like in RAM\ROM megafunctions in quartus, using mif or hex files ? My board is DE2. Software Quartus II Web Edition. I don't want...
16 years agoI don't see how the fpga can do any processing before it is configured and alive.
But why do you need to initialise SRAM. if you need external lookup tables then you must use flash memory. If you mean vhdl code to initialise then you can write to SRAM
