in MAX 10 Dev kit
Hi Altera Community,
I am encountering a JTAG Server Error Code 35 when attempting to program my MAX 10 Development Kit using the USB-Blaster.
Below are the details of my setup and the issue:
Board: MAX 10 Development Kit
Programmer Cable: USB-Blaster
Problem Description:
When opening the Quartus Programmer and clicking Start (or running Auto Detect), the process fails with the following log:
Error (209053): Unexpected error in JTAG server -- error code 35 Error (209040): Can't access JTAG chain
- Hetvi
New Member
Yes, exactly. I am powering the board separately via USB and using a dedicated 10-pin USB-Blaster connected to the JTAG header for configuration.
- sstrell
Stupid question: you're powering the board via USB power and using a separate 10-pin USB Blaster cable for configuration? This board does not appear to have an on-board USB Blaster so you need the standard 10-pin JTAG connection to the board. You can't program the device with just the USB connector.
https://docs.altera.com/r/docs/812857/current/max-10-fpga-10m08s-evaluation-kit-user-guide/supported-items-not-included-with-the-kit
- Hetvi
New Member
ITS POWERD VIA USB ...ATTACHING THE DEV KIT LINK MAX® 10 FPGA 10M08 Evaluation Kit (POWER SOL'N 1) | Altera
