15 years agoImporting already done proj into NiosII IDE
Good morning,
as you know kits come with examples with done projects, i would try only to modify a little part of a software file but leaving all the remaing files/directories unchainged. For example I want to use: ...\kits\cycloneIII_3c25_niosII\examples\application_selector inside \application_selector dir there is \software example and then \app and \bsp. Now, how can I set a new workspase into Nios2 IDE and import or set the environment so it can use the application_selector project? Thank you John11 Replies
Hi Andreas,
yes, I have contated altera's support, the problem could be the sw versions I'm using, I'm trying to update my examples files for QII & NII 9.1sp2 because the examples on the CD were done for v. 8.0 (on my CD). Maybe next week I can try to do something! thanks John
