16 years agoImage Processing Project on the DE2 board
Greetings! I am making this project using the DE2 development board (with a CMOS Camera and LCD display attached) which has the following objectives: 1. Capture an image 2. Display the I...
16 years ago --- Quote Start --- And your JPEG Algorithm Reconfiguration controller should work (with Quartus disconnected) by scanning in a new algorithm from PC to FPGA via some pre-defined interface. --- Quote End --- And from SD Card to FPGA via the interface shown in the diagram can be done as well right?:) So is the diagram I drew good enough? Does it miss something or is anything wrong with it?
