16 years agoImage Processing Project on the DE2 board
Greetings! I am making this project using the DE2 development board (with a CMOS Camera and LCD display attached) which has the following objectives: 1. Capture an image 2. Display the I...
16 years agoIt looks like your projects needs a lot of software work.
The only hardware seems to be the JPEG compression. If you don't have strong real time requirements this also can be done in software. Probably the NIOS allows to better implement all this controller stuff. Hope this helps
