Idaville LCC I2C layout trace length
- 2 years ago
Hi Lisa,
I have got input from the internal team as below:
All these recommendations in the tables in section 13.1.2 were put together using simulations by our Signal Integrity Team.
I checked for example the guidelines provided in the Whitley PDG (doc# 574174). Whitley is the platform for ICX-SP, which has a different PCH than ICX-D. Checking table 6-36 in the Whitley PDG I see similar number to the table 13-1 in the Idaville PDG. It seems that even with a different PCH they arrived at similar conclusions.
You also can run your own simulations and if you think the board is able to handle longer traces, they can do it, but Intel can’t offer support if they deviate from our recommendations.
Aqid
I feel like this post is getting "Platform Design" confused with the "Platform Designer" tool found in Quartus since this doesn't sound like it has anything to do with FPGAs.
Hi Sstrell:
Aqid is helping asking Intel internal team for reply, And I have transferred from other forum,they told me should post in this forum.
Or I donot which forum should I post and It will waste too much time.
Best Regards
Lisa
