Idaville LCC I2C layout trace length
- 2 years ago
Hi Lisa,
I have got input from the internal team as below:
All these recommendations in the tables in section 13.1.2 were put together using simulations by our Signal Integrity Team.
I checked for example the guidelines provided in the Whitley PDG (doc# 574174). Whitley is the platform for ICX-SP, which has a different PCH than ICX-D. Checking table 6-36 in the Whitley PDG I see similar number to the table 13-1 in the Idaville PDG. It seems that even with a different PCH they arrived at similar conclusions.
You also can run your own simulations and if you think the board is able to handle longer traces, they can do it, but Intel can’t offer support if they deviate from our recommendations.
Aqid
Hi Lisa,
Can you share which page it is? I may need to consult the internal team who owned the documentation.
Aqid
Hi Aqid:
Item 13.1.2 on Page 567 & 568 of document <Idaville LCC Platform Design Guide(PDG) Revision 2.4 November 2023>.
Best Regards
Lisa
