I2C Remote System Upgrade Example - No output on the Serial terminal
After checking with my team, by looking back at your first post regarding not able to see anything on serial terminal, kindly try to check again the theory of operation starting on page 3 of the I2C RSU user guide.
Also, on page 16 of the I2C RSU user guide, please check again the USB to UART system setup. Make sure to select the correct COM port. This to ensure the device is correctly connected.
For serial port setting, try to play with the Baud Rate setting. You can try to change the Baud Rate.
Aiman
- RVadl25 years ago
Hi.
Thanks for the suggestions. But I think there is no issue with UART and the Baud rate as I am able to run other codes and see the output on the Serial terminal. I think the issue is with the loading of nios_firmware.pof in to QSPI flash, because this never passes the verify step in the programmer. I really doubt whether the nios_firmware is loaded or not.
Ravi Kanth V
