RVadl2
5 years agoI2C Remote System Upgrade Example - No output on the Serial terminal
I am trying out the below i2c example for RSU with Max 10 Evaluation kit
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/i2c-remote-system-update-example/
I am using the file...
NurAiman_M_Intel
5 years agoHi,
Sorry but I am confuse. So, are you looking for design file for RSU via I2C? Because it is in the RSU via I2C design example.
For this design example, please follow the instruction available in theory of operation for the initial configuration:
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/9/9a/User_guide_151.pdf (Page 3)
RVadl2
5 years agoHi,
Let me try to clear things. The RSU via I2C design file(i2c_master.c) is present in the design example folder. But this is different from nios_firmware.pof. And nios_firmware.pof is not the same as the one in AN741 also.
There should be a different design for RSU.sof and its not I2C_RSU. The user guide says these are files from separate project on Altera Design Library
Hope I brought some clarity
