RVadl2
5 years agoI2C Remote System Upgrade Example - No output on the Serial terminal
I am trying out the below i2c example for RSU with Max 10 Evaluation kit
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/i2c-remote-system-update-example/
I am using the file...
NurAiman_M_Intel
5 years agoHi,
Have you tested with the method using Remote Terminal.exe which is to update MAX10 with UART? This is to check if the IP is instantiated properly.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf#page=12
Aiman
RVadl2
5 years agoI have tested AN741 and was able to trigger the Remote system upgrade from UART. But my final system is something similar to the once explained in
Where I need to update 10M16 using 10M50. So it would be grate if I could get the source files that generated the output files :“RSU.sof” and “nios_firmware.pof” mentioned in those examples
Thanks in Advance.
