I2C Remote System Upgrade Example - No output on the Serial terminal
Have you tested with the method using Remote Terminal.exe which is to update MAX10 with UART? This is to check if the IP is instantiated properly.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf#page=12
Aiman
Hi, I have one more query. In the example below
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/i2c-remote-system-update-example/
IN Pg-19 the below statement is written
"Note that this section does not contain instructions for regenerating the programming files used for the UART section of this example (“pfl.sof”, “RSU.sof”, and “nios_firmware.pof”). These files are part of a separate project which can be found separately on the Altera Design Store."
Can you please point me to projects in Altera design store containing the above files
