I2C Remote System Upgrade Example - No output on the Serial terminal
Have you tested with the method using Remote Terminal.exe which is to update MAX10 with UART? This is to check if the IP is instantiated properly.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf#page=12
Aiman
- RVadl25 years ago
Hi, I have one more query. In the example below
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/i2c-remote-system-update-example/
IN Pg-19 the below statement is written
"Note that this section does not contain instructions for regenerating the programming files used for the UART section of this example (“pfl.sof”, “RSU.sof”, and “nios_firmware.pof”). These files are part of a separate project which can be found separately on the Altera Design Store."
Can you please point me to projects in Altera design store containing the above files
- RVadl25 years ago
I have tested AN741 and was able to trigger the Remote system upgrade from UART. But my final system is something similar to the once explained in
Where I need to update 10M16 using 10M50. So it would be grate if I could get the source files that generated the output files :“RSU.sof” and “nios_firmware.pof” mentioned in those examples
Thanks in Advance.
