Zhilang_X_Intel
7 years agoI would like to build a connection between my master device and max v, so I program an i2c interface logic to max v which I download from opencores. But I can read from my master device but can't write correctly to the MAX V cpld.
I would like to build a connection between my master device and max v, so I program an i2c interface logic to max v which I download from opencores. But I can read from my master device but can't wri...
Zhilang_X_Intel
7 years agoThanks for your advice. But the an486 example set the MAX FPGA to a master not a slave, and I just set my MAX V to a I2C slave. So could you please help me review my I2C_to_GPIO_modify file?
EBERLAZARE_I_Intel
7 years agoHi,
Are you facing the write issue using the code entirely from opencores? I am unsure if the code are supposedly targeted for MAX V device.
I am not really familiar with verilog, but you probably want to get the register address code to work first since the an494 example is already working.
Regards.
