I would like to build a connection between my master device and max v, so I program an i2c interface logic to max v which I download from opencores. But I can read from my master device but can't write correctly to the MAX V cpld.
Hi Liam,
Great that the example design did work, I noticed that the example design an494 demonstrate no register address, we do have another example design that have command register:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an486.pdf
However this example design demonstrate the MAX FPGA devices serve as a bridge between a host that has serial peripheral interface (SPI) to communicate with devices connected through an I2C bus. This may be as close as what you are trying to achieve.
Regards.
Thanks for your advice. But the an486 example set the MAX FPGA to a master not a slave, and I just set my MAX V to a I2C slave. So could you please help me review my I2C_to_GPIO_modify file?
- EBERLAZARE_I_Intel7 years ago
Are you facing the write issue using the code entirely from opencores? I am unsure if the code are supposedly targeted for MAX V device.
I am not really familiar with verilog, but you probably want to get the register address code to work first since the an494 example is already working.
Regards.
Are there any update to this issue?
Regards.
Hi Liam,
Since the example code that you shared is not for targeting our MAX V devices, it is difficult to debug why it failed when adding the register address.
I have sent out an example of a design file of MAX V via message, can you check it out?
Regards.
