brajesh_1988
2 years agoI want to connect two different ips in platform designer tool like core and AVMM ?
I am using Platform designer tool in the quartus prime software and i want to connect two ips , like connect to peripherals and AVMM . I need an interconnect between the two which can talk to the cor...
sstrell
2 years agoStill not clear what you are looking for. Platform Designer builds an interconnect when you generate a system. If you are saying that you want to connect something outside a PD system to components inside a PD system (without turning it into a custom component to connect directly inside PD), you can export an interface (like Avalon memory-mapped) out of the system and connect it to something through standard HDL instantiation using the generated instantiation template created by PD.
