ab4's avatar
ab4
7 years ago
I try to write vhdl program to model an 8bit serial in parallel out shift left register with active high synchronous rest and active low asynchronous set input. am I in the right way?
Library IEEE;
USE IEEE.Std_logic_1164.all;
entity RisingEdge_DFlipFlop_AsyncResetLow is
port(
Q : out std_logic;
Clk :in std_logic;
sync_reset: in std_logic;
D :in std_logic
end RisingEdge_DFlipFlop_AsyncResetLow;
architecture Behavioral of RisingEdge_DFlipFlop_AsyncResetLow is
begin
process(Clk,sync_reset)
begin
if(sync_reset='0') then
Q <= '0';
elsif(rising_edge(Clk)) then
Q <= D;
end if;
end process;
end Behavioral;
1 Reply
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    You have to be more clear on your requirements.
    Question and implementation are different, in question you have mentioned "active high synchronous rest" and in code "AsyncResetLow". However your design is correct as per Asynchronous Reset Low.
    For reference go to the template provided in quartus under edit->insert template->VHDL->Full designs->Shift Register.
    Example:
    	process (clk, reset,enable_n )
    	begin
    		if (reset = '1') then --Active high Asynchronous rest
    		elsif (rising_edge(clk)) then
    			if (enable_n = '0') then --Active low synchronous enable
    			end if;
    		end if;
    	end process;
    Anand
