NZami
7 years agoI have cyclone 10 lp FPGA with cypress serial flash as the configuration device. In order to burn my firmware to the flash (using jtag and Active Serial mode) I want to use pof file. Is it a problem?
NZami
7 years agoHi vicky,
I hope you can help me, I have problem to generate the jic file.
I generate new NIOS and generate code with eclipse (elf file).
From the elf file I generate HEX file for initial the NIOS processor.
After synthesis my code I burn the sof file to my board and its work.
When I try to generate the jic file I get error the HEX file is not good and that
"data in HEX file is overlaps between data blocks at address 8 and address 0"
What is problem and how can I fix that?
Niv.
