Chandrashekhar_K's avatar
Chandrashekhar_K
3 years ago
HPS BareMetal LED toggle Example for Altera Cyclone V Developement Ki
Kindly share working example to toggle LED/GPIO of HPS
Kit : Cyclone V SoC Development Board
Platform : Bare Metal
  • Hi,
    I will try to find, test on my side and give my reference project to you
  • Hi Mabdrahi,
    Thank you3 for sharing the document and the LED example.
    I think the example is for linux environment.
    It would be of great help if the code for bare metal is available.
    Thank You
    • Chandrashekhar_K's avatar
      Chandrashekhar_K
      I could get a sample example from the community, struggled a bit to get it complied.
      Now the LED example is working.
      Thank you.
  • Hi Chandra,
    I hope you doing well,
    Any stuck or progress status on your end?
  • p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
  • Assistance Needed: Trouble Running Bare-Metal Code on Cyclone 5 HPS
    I am working on intel cyclone 5 hps I have two cores in a processor Core 0 core 1, I want two code to run on two different cores core 0 and core 1 in bare metal .
    When I run in jtag mode it works, for jtag i first debug using core 0 where i take core 1 out of reset it, than debug core 1 usign jtag it work
    BUT, When i want to run both core usign qspi it only run core 0 not core 1
    Here is the step i followed
    Firsly, loading preloader
    quartus_hps -c 1 -o P preloader-mkpimage.bin
    I make an image from bin file of core 0 and place it to qspi
    mkimage -A arm -O u-boot -T standalone -C none -a 0x00060000 -e 0 -n "baremetal image" -d core0.bin core0.img
    quartus_hps -c 1 -o P -a 0x00060000 core0.img
    I make an image from bin file of core 1 and place it to qspi
    mkimage -A arm -O u-boot -T standalone -C none -a 0x00100000 -e 0 -n "baremetal image" -d core1.bin core1.img
    quartus_hps -c 1 -o P -a 0x00100000 core1.bin
    When i restart board only that code work which is in core 0, core 1 code not executing
    I am setting cpu1startaddress 100000 apart from that in the code of core 0 also i am using alt_qspi function to to place bin file data in ddr,
    I want to run in smp mode so I also set required aux_control_register smp and fw bit as stated in tech ref manual
    alt_qspi_read((uint32_t *)BL_START/*ddr3 address*/, 0x100000/*qspi address*/, 0x40000);
    In linker/scat file core 0 entry point is 0x60000 and
    linker/scat file core 1 entry point is 0x100000
