19 years agoHowmany times program in EPS1 flash
Hi !! The FPGA device can be programmed at any time using the JTAG port (using a .sof file), or by the EPCS1 serial flash device at board power up. Here my question is Howmany times we ...
19 years ago"■ Re-programmable memory with more than 100,000 erase/program
cycles" - on the first page of EPCS datasheet : http://www.altera.com/literature/hb/cfg/cyc_c51014.pdf (http://www.altera.com/literature/hb/cfg/cyc_c51014.pdf) Overwrite is posible in EPCS. Erase cycle insert automatically before each new write cycle in QuartusII programmer.
