how to write data to fpga side sdram on cyclonev
I will be working on this case.
Please do allow some time to go through this case. I will reply ASAP.
Tiwari
Thanks for your reply!
I have find out the reason of my “bus error”,it was because that I set the a wrong value of L3 register bit3.it should be 1 to enable the axi master,but i set it to 0 and the master was disabled.
However,i met another problem when i set correct L3 register.My code like this
any time i ran the code,it showed "write finished" and then was stuck.
i am a rookie on cyclonev and i have just learned this forweeks,i am sorry that my description may be unprofessional.if you can present me some easy examples of how to write data from hps to fpga ddr3 on cyclone v, it will help a lot.
thanks again for your answering my foolish problems
