16 years agohow to using USB (CY7C68013) with Cyclone III
Hi, I have 2 questions regarding Cypress CY7C68013A with Cyclone III. Which SLS usb ip is the right one? Does it allow USB to get connected to Avalon Bus? Thanks, gl888
16 years agoYes, I would expect the same. Generally, both chips are representing different concepts. Cypress has implemented a sophisticated method (GPIF) to achieve optimized data transfers even without fast programmable logic. You don't necessarily need it when interfacing a FPGA, but it can still ease your work.
