16 years agohow to using USB (CY7C68013) with Cyclone III
Hi, I have 2 questions regarding Cypress CY7C68013A with Cyclone III. Which SLS usb ip is the right one? Does it allow USB to get connected to Avalon Bus? Thanks, gl888
16 years agoMany thanks for the suggestions.
As for realistic data throughput, may I say there is no obvious advantage one vs the other (i.e. CY7C68013a vs. isp1504, or the other way around), given that the interface logic has been well designed to handle the setup and automatic data transfer (master mode with good buffer size)? Best regards, gl888
