16 years agohow to using USB (CY7C68013) with Cyclone III
Hi, I have 2 questions regarding Cypress CY7C68013A with Cyclone III. Which SLS usb ip is the right one? Does it allow USB to get connected to Avalon Bus? Thanks, gl888
16 years agoThe CY7C68013A EZ-USB will not connect directly to the Avalon bus, you will need to write a bit of logic to do that. How much work the NIOS core will have to do will depend on how sophisticated that logic is.
As FvM said, it provides a fast FIFO interface so there's not much for NIOS to do in terms setting up the transfer. However, the EZ-USB buffers can't hold more than 4 packets at a time. Note that at full speed (12 Mbit/s) each packet can be 512 bytes but at high speed (480 Mbit/s) it's only 64 bytes. So, a minimal effort solution would require NIOS to read/write data in batches of 4*pktSize or less. If this is not good enough, you can improve this by making the interface a bit more sophisticated. You can add some FIFOs of your own to the Avalon/EZ-USB interface to increase the batch size. Or you can have the Avalon/EZ-USB interface perform DMA transfers directly to the NIOS RAM. In this case, I'd look at EZ-USB's Master mode, I think it should simplify the DMA logic.
