16 years agohow to using USB (CY7C68013) with Cyclone III
Hi, I have 2 questions regarding Cypress CY7C68013A with Cyclone III. Which SLS usb ip is the right one? Does it allow USB to get connected to Avalon Bus? Thanks, gl888
16 years agoHi, Max,
Thanks for your suggestion. Would you please give me a little bit more light on why ISP1504, usb3300, max14516 is better? Do they offer higher bit rate? (by the way, I cannot find any information on max14516) In my application, USB is used as communication path for downloading data from PC to DDR2 on FPGA board. There is any embedded NIOSII processor. Data rate is important. I may not need the feature of OTG/host. Is there any benefit in CY7C68013A since it has a extral 8051? Can I use the 8051 to help automate the data transfer through USB and save NIOSII's bandwidth? Best,
