16 years agohow to using USB (CY7C68013) with Cyclone III
Hi, I have 2 questions regarding Cypress CY7C68013A with Cyclone III. Which SLS usb ip is the right one? Does it allow USB to get connected to Avalon Bus? Thanks, gl888
16 years agoCypress CY7C68013A is an ancient USB2.0 solution. You should use a newer USB PHY with ULPI when using SLS's USB2.0 IP cores. For example more up to date USB2.0 PHYs are the NXP ISP1504 , MAX14516 or SMSC usb3300.
Cheers, MAX
