17 years agohow to use the loopback boards?
With the Cyclone III dev kit, there is 2 loopback boards provided. What is it for? How is it used? I couldn't find the documentation for it. Thanks.
17 years agoif you've installed the CIII development kit files the loopback schematic can be found at:
C:\altera\72\kits\cycloneIII_3c120_dev\board_design_files\schematic\loopback_hsmc\debug_header_breakout.pdf match the signals with the HSMC connector on the board schematic at: C:\altera\72\kits\cycloneIII_3c120_dev\board_design_files\schematic\c3_f780_host.pdf then you can run signals out of the FPGA, through the loopback adapter, and back into the FPGA.
