matif
6 years agoHow to use FPGA side SDRAM on Cyclone V SoC
Hi, There are two SDRAM (each of 1GB) on cyclone V SoC (Arrow Sockit Board (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=816)) (5CSXFC6D6F31C8ES), one for HP...
NurAida_A_Intel
6 years agoHi matif,
Seems like the simulation is still running. It require some times to be completed. If you are running with "Full Calibration" mode, the estimated synthesis time taken is much longer.
Anyway, this is just the estimated time. The real simulation time for your design may vary depending on the memory interface specifications, simulator, or the system you are using. And it is recommended to use correct Synthesis tool (ex: ModelSim, Synopsys..etc) that is compatible with your Quartus version.
Also try using other simulation tools for better simulation times (For eg : synopsys VCS simulation run time is much faster as compared to other tools) as different synthesis tools give different results.
NAli1
